Take out the idle mixture screws & afix one of those thin red straws that come on a WD40 can to a can of Brake Kleen & shoot a 2 second blast into each port. Count the # of turns in to lightly seated so you can easily return the screws to their original position. Might have a vac leak. E10 (ethanol) will make it want to stall when hot
