Old 12 valve totally different animal. Crank sense on those was soley to let the SBEC controller know the engine was running. 2000 VP equipped truck has two controllers. The JTEC controller on the firewall is the brainchild for the charging system. Cam and crank are present and engine starts is all done throught the ECM on the engine block.
