I dont have the corner weights in front of me but I know it was 57.28% front and 42.72% rear distribution. Front was about 100# heavy on the drivers side with me in it, race ready. And exactly 55lbs more on the right rear. Also went from 7.5psi to 6.25psi and two clicks stiffer on the QA1's. After reviewing the video I can see the rear does a little bounce after the front is done rising and then the car gently back down. Seems to me like the shocks are being fully extended.
I havent really had time to get back under and check.
Thanks for the kind words
