You can run the small diameter pushrods if you want. But you cannot run the larger diameter ones with the smaller lifter setup.
To be honest, push rods are cheap enough that it's probably best to update to the later ones from a 440.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
