Very informative and interesting comments there Savoy man. I was wondering if the syncro hub and slider teeth get chewed up as much with the dog and ring style. The way power changes from one gear to the next has changed, but not how you connect the hub to the slider. I've seen this before on a factory slick shifted 18 spline. I guess shock loading at 6000rpm does stuff like that.
