Spool k-member out of a 73 dart sport.The engine would have to move a couple inches up and to the passenger side to help this problem.The rear tube is close enough to the steering column that I think it will melt the plastic insert where the steering shaft exits the column.Looks like the coulmn shift linkage will need modified as well even though tti's website states these work with column shift.
