I adjusted the kick down linkage and man oh man what a difference! I can tell now what a shift kit is all about and it is a blast to drive! Floor it and it will chirp in 2nd gear. I could not contain myself and was running down the road like a teenager. Thanks for everyones' help and to those who mentioned that I should check kickdown adjustment you were spot on.
