when idling....it hangs around....when throttling there is no smoke.....when it comes off the throttle...a PLUME of white smoke comes out and then steadies out in a continuous motion. When I pop out the plug to do a compression check I will check the plug for abnormal signs...I just put a new set of Champions in there...so it should be an interesting find
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
