I held the the carb wide open while attempting to crank it but no go. I have flooded it before and that always worked up until now. Found my timing light and it did flash as engine cranked so I guess that means I have spark from the dist. to the plugs. Will try the plugs next. Probably overthinking this because I panic at thought of electical problems. Thanks.
