Re: 230 - 260 leaf springs and 1.26" torsion bars
[Re: TC@HP2]
#1485530
08/19/13 05:13 PM
08/19/13 05:13 PM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
... However, if you really have everything speced around that, talk to Dick at Firm Feel and see if they could whip up a one off set at 1.24, which, coincidently, is the biggest you can put in the factory E body sockets. To go bigger, you need to convert to C body sockets.
Also, are those rates you have calculated including sway bars at all? ...
yes, I did factor in the sway bars and converted it all to wheel rates.
Thanks for your advice. I'll get in touch with Dick Ross at FirmFeel and see if he can make me a pair of 1.24" torsion bars.
