ok so the owners manual says the seat belt has to be hooked in before she will crank.there is a relay on the apron that is for it.the om says to push the center of the tube in on it to crank without the seat belt being connected for service use. I tried it doesn't work.I used my remote start button and it fires right up.I also noticed it has no neutral safty switch on the trans.Where does it pick up the reverse lights.? Does any body have a wiring schematic for a 74 gold duster? I need to track this down.Seems like a funky setup.I have no signal at the starter relay.
