Quote: What is the source of boost to the regulator? Is it above the throtlle plates or below?
The boost reference should be what the injectors are seeing inside the manifold (assuming they are in the manifold). Manifold pressure - below the throttle plates.
Carb application... I assumed FI. Comment above not applicable!
