Unplug the crank sensor and see if the affected sensors start reading right. Have had those in the past short out and cause all kind of no start and no communication issues.
If that's not it start unplugging one 5v sensor at a time and go from there.
Does your scanner comm over the PCI bus or generic bus?
I have unplugged all of the effected sensors and the crank sensor,with no change. I am going to try the cam sensor in a little while any others I should try? I am going to say it is the generic bus as it is just a cheapo scanner
1969 Super Bee High School car I got back 2004 Ram 2500
