Quote: .make sure the original alt output wire in the harness is disconnected from the alt.
Is there ANYTHING else that needs to be disconnected to do this mod? Under dash, at start relay, etc... I am running a stock replacement alternator (65 amp) that is the externally regulated 3 wire. Thanks for your help!!
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
