How many have used it? Does it give a different pedal feel? Since I did all new everything on the Bee, and it will sit all winter, I filled it up with silicon fluid. The pedal feel doesn't make me happy. Is there a different 'feel' to it, or do I need to keep bleeding?
I bench bled the master cylinder, and I have bled each line ttwice starting from the right rear. All connections are tight, no leaks, and no more bubbles! I will most likely hit them again when I go through the mental checklist before I drive it out of the garage. Just looking for your thoughts.
Richard E., you out there?!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
