Quote: Stumped the "MOPARTS" crowd? Say it isn't so!
Here's a pic of my GTX, lines look a little "goofy" but original with no "kinks" from turning them around.
I went through all the '70 b-bodies on the 'bay; most of the power disc brake lines are toward the inner fender but there are a bunch toward the engine?
I never saw this , the ones toward the inner fender were NORMALLY found on HEMI cars , but I guess a few could have gotten thru the other way if the toward the engine units weren't in stock at build time ???
BUT looking at that particular master and knowing what I know , that is NOT a correct B body master cylinder for 1970 , that looks like the later E/B body and everything else unit , plus it should be painted BLACK , that's been replaced somewhere along the line
Just looked at the pic again , it APPEARS that SOMEONE also bent those lines to meet up with that master cylinder .
