I installed their underdash system on my 67 Coronet. I had to modify the switch to get it to work, but my dash is an aftermarket one with the stock slots. So I'm not sure if it would be perfect if my dash was completely stock.
Using this kit http://www.bpeusa.com/BPE4715.asp
I made my own hoses.
Plus I did a better belt arrangement that grabs more of the pulleys than how they have it. Crank belt only drives A/C instead of both the waterpump and A/C.
