Is there a right way to run the transmission cooler lines for a B&M cooler. I have it mounted up front with 2 -6 lines going to it. Should the outlets on the transmission work better if say the front outlet goes to the top or the rear outlet goes to the top. Just trying to make sure it is 100% correct. It is a big block 727. Thank you for your help.
