Call Brandon Burns, the guy who started this thread:
http://www.dakotart.com/forum/showthread.php?t=17734
He CNC cuts his own billet hubs and then drills them to whatever bolt pattern you want.
I think he was charging around $300 shipped for the pair of front hubs
then call Moser and order yourself a set of rear axle shafts, also drilled in whatever bolt pattern you want. Cost for those was around $350 last I checked.
in the end, you get a real, "correct" 5-lug conversion for less than $700, and your aftermarket/custom wheel selection opens up, AND they are cheaper.
Or you can do the fill/drill on your original hubs/axle shafts for a lot less, and hope the welder didn't have an off day.
**Photobucket sucks**
