The right side is the easy part...The heat riser usually hits though and needs to be removed.
The left side may fit with manual steering if the steering column jacket is trimmed back. I have heard of guys milling the manifolds at the port side, cutting more from the bottom to angle the exit flange in toward the block. This helps with the angle of the exhaust pipe.
