well i picked up the 88-tbi 318 from a B-150 van today for 300$
ordering up a whiplash roller cam/springs and will be doing a backyard frshin up with it.
all new gaskets with a nice roller cam swap alittle paint and it will be good to go with the 5 speed conversion in the 88 truck.
once I get the engine 5 speed swaped in i order up a rear disc brake conversion from DrDiff next.
whiplash/5 speed/disc brakes
I am going to list some of the stuff off this 318, it was a non-a/c with a mini alt.
nice brackets and it has the a/c delete pull someone was looking for the other day too.
nice truck manifolds,working heat valve and a o2 sensor on the other side...seems someone was wanting a set of center dumps here also.
the TBI engine harnes looks to be un-cut and in good shape,i may pull the main batt wire and the feild wires for the mini alt and trans plate then into the 85 harness i used on the 88 truck with the mini alt.
some pics to drool over.
