Zero deck 440 with SRP's flat-tops -6cc valve reliefs...MP 590, 75 cc Edelbrocks, Marine Fel-pro's...
Anyone run into issues with the cam in @ 102-104?
are you running this cam now ? if so what is it in at and what is your current piston to valve clearance?
The only cliques are those that people create for themselves.
