I had to switch blocks, old block had lifter bores bushed with no oil holes I added oil restrictors to the heads . New block the lifter bores are not bushed same heads. Pushrods are starting to get some color has to be a oil issue. First thing I'm thinking is remove the restrictors in the heads. What do you guys think.
Rockers are oiled through the shaft
AL
