I installed a new turn signal switch on my Bee last year and I thought it was working fine. However, I just noticed an issue where if I turn on the blinker, turn it off AND I don't get the stalk centered enough, the blinker stays on. The dash doesn't show that the blinker is still on, so I just cruise with it on for miles. When the car is not running, you can hear the relay clicking but the dash isn't lit up indicating this. The issue only happens when the stalk itself is not centered. Also, when turning a corner, it correctly snaps the stalk back to center and there is no issue. Is there anything I can do to fix this, or do I have to order a new signal switch?
![](/ubbthreads/images/graemlins/flame.gif)
