Quote: No, that is an INCORRECT STATEMENT in my application, a 76 D100, I had to change the rotors due to the rear bearing. (The big one) being a different size. I wanted to keep my 5 on 4.5 bolt circle. Possibley different on other applications.
You could have simply used 80-84 2wd Rotors
Yes that is simply what I used. They are the same part number as the Newyorker rotors. So I've said this at least twice before, in my application to use the Dakota spindles I had to change rotors. I could not use the original 76 D100 rotors with the Dakota spindles. Does that sink it yet? Josh-
