More problems. Before I could make any new readings the car died; like turning the key off. Car would not restart. Today I ohmed the coil (MSD Blaster #8222) Primary 1.1 ohm and secondary 5.433 Kohm. MSD website says for this coil primary .7 ohm and secondary 4.5 Kohm. Should this coil even work at all??
Car started and ran just fine but alternator is still not putting out. FYI battery voltage is 12.77. Voltage at + coil (blue wire) 12.61 and voltage at Alt terminal (blue wire) 12.61
