Check the voltage at the alt "batt" stud. Just to be sure jump from the green wire spade to the batt neg post rather than to the alt case but so far it's looking like the alt is bad. Might jump fire from the batt positive post to the blue wire spade field terminal on the alt just to be sure the field is getting fed full voltage
