Yes I was at the limits. I told the guy to get zero camber & as much positive caster as he could & that's what he came up with. He opionated that something might be bent but nothing jumped out at me when I put it together from scratch from a roller. I dont remember if I used any poly but I think I was sitting on the kit for quite awhile & used it & it was all rubber. EDIT Would you suggest 1 or both offset bushings?
Both
