I'm getting ready to do this myself and have no idea how this comes apart. How do you get the foam/ rubber section out to get to the rails? Does it simply pry out?
I have to replace both sides-as water is getting in along the top edge of both- not to mention that a section of the outer foam area is missing on the driver's side.
ANY instruction would be greatly appreciated!!!
