If it is a manual VB there will be some holes in the rear of the red plate that aren't used (pic doesn't show rear).
Also the throttle valve will be jammed wide open (there won't be any spring feedback when turning the throttle lever shaft).
The INTERNET, the MISinformation superhighway
