One more fact - the engine diesels for 1-2s after shut off. We tried 3 different plug heat ranges and no difference. Also minimizing advance even to 0/20* does not eliminate it. Idle is 900 rpm.
Automatic? If so does it diesel if shut off with the trans in gear? If not consider installing a idle solenoid, with that done the standard idle screw is backed out completely & idle is set with a screw touching the plunger of the idle solenoid.. That way when power is shut off to the solenoid the throttle closes completely...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
