They didnt mention the built in map sensor when i called. Good to know.
Ive heard they are a bit tricky to setup right, but i like being able to adjust things around to my liking.
So i see your located in Chandler AZ, I fly out for business there almost every month, would you mind if i checked out your truck? Lunch is on me or possibly a Asian hooker? lol
Also what about chassis support? Have you added any structural integrity for the frame? Roll cage, ect?
I will be following this guide/build sheet for the next 3 months. Got a fatty 10k commission check coming in i just found out about. So I have my spare block, i have a stock pile of motor parts, I am in the middle of rebuilding the entire front end, (tubular control arms, upper lower ball joints, tie rods, rotors, brakes, rack and pinion, immediate steering shaft)...once this is finished im going to start on the motor right away.
I am also going to do almost all the work my self, except for alignment, dyno, piping, welding (unless i buy a welder, possible MIG), and possible get some help on the tuning.
Anybody know any good v8 turbo shops in austin tx area?
