Have a 74 Powerwagon. Decided to drive it today to unload the stuff I had in the bed and toss some stuff in for scrap. I put some aluminum rims on and used it to plow snow this winter. Well on the way home it got a slight sake Si I pulled over to investigate. The pass front wheel had come loose and snapped a stud. It only had 4 lugnuts to start do to 5th studs threads being screwed up. So question is what's involved in replacing the studs? I plan to replace all 5
