I've used those for quite a while. Make sure the outlet fitting isn't touching the pintle. There is actually a BG spec for minimun clearance.
If I recall, they sold a special fitting for in that regulator. Nothing more than a shortened standard AN fitting.
If the results don't match the theory, change the theory.
