I would say yes. it is taller than the one on the left.
and looks like the one in my 3rd pic. you would need to tweek the 2-v rod or find the correct 4-v rod.
the trans will use a long TP lever.
FYI,they have short and long and have the D-hole clocked in different spots to adjust the ratio.
so you can mix match them to get it spot on with the adjustment in the middle of the ratio( I hate it when you are on the tippy end of a rod and still need a tad more adjustment. )
I have plenty of the levers and linkage parts if you need something.
