here it is on a tall rpm intake. I did riase the throttle cable clamp so the cable was level with the stud since this pic.(and they said stock linkage wont work on the RPM intake...)
stock 78-440 truck 3-piece linkage
just swaped a 3-piece set up over to the 85 318/727 replacing the 1 piece set up. it is off a mid 80s SB 4-v dippy. much more adjustability with the 3 piece.
if you need the tall intake bracket for the B-engine,AREngineering has them.
scratch it looks like we have the same setup, it your throttle cable goig at an angle to the carb. mine might as well be in the back of the carb
