Sorry I missed the Neutral part. Sounds like a balance problem. did you have the engine balanced internally and put on a weighted or B&M flexplate. Or did it get balanced for standard cast shaft balance and you didn't use the weighted plate or damper. (Don't know exactly what you have so throwing things out at you)
