I was concerned about the raised roll center also.
Suppose you are in a drag car, with no sway bar and loose shocks and suspension. You hit a greasy spot at half track and get a little sideways. Will that higher roll center hinder your recovery? Will it cause the car to gyrate back and forth until you lose it? Or is it no big deal, won't make any big difference?
BTW, does any one know if software like they used can be downloaded free anywhere?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
