think cheap first----the jag XJ6 is used alot because it is easy----buy a whole car for $500 take off the rear cradle and unbolt the front clip--4 bolts then put it on your rod---crush the rest for $300-------this car will have the best brakes you can find for a 80,s vintage and the rear uses dana 44 gears and is stronger that the corvette setup....bob
