I think this is what it would look like, however I'm not sure since there is no part # at the valve stem on this wheel.
Anyone know what this 14x6 wheel is for? early 70 maybe?
I believe the # should be printed on the inside of the rim (facing inside the tire). If no number there, it's likely a 329...either way, looks correct for a 71
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
