The standard 14" trim ring part number 2944 424. I believe that you can get the re-issued ones at your local Chrysler Dealer. They will have a "P" in front of the newly issued part number. Maybe someone can confirm this, and what the new part number is. As far as the 14x6.0's go, you are S.O.L. as far as reproduction goes, you will have to try and track down some.
