OK, let's look at the physics; the valve body has no way of knowing the band lever ratio, the band adjustment, the front clutch clearance, the front clutch spring pack, etc. all of which contribute to the 2-3 shift overlap or lack of.
To say any VB will eliminate ALL overlap is good advertising but not very realistic, more likely is the claim to eliminate excessive overlap.
The INTERNET, the MISinformation superhighway
