Trying to figure things out on my new LA SB, are aftermarket main caps woth it or should I just stick with the stock caps. We've all heard the 4 bolt caps weaken the block but does anyone have any actual experience with this? Any help is appreciated.
Got about 16 runs on mine so far with no problems (probably in the 650HP range). Block is filled though.
Fastest 300
