Without the full voltage after warm-up, the choke spring will cool off and apply the choke while the engine is warm, only source of heat to keep the choke spring relaxed.
Not in my case,my choke assembly is from a 62 300H with internal constant vacuum operated piston to keep open same as later Hemi choke assemblies,along with engine heat,I have no problem with choke staying open after voltage cut off.
