69 b-body w/383. edelbrock carb. where would be the best place to wire in my electric choke ?
I'll tell you the wrong place ... I don't give a [censored] what anyone else has done ... the positive side of the coil.
While this is the proper circuit and will get power when the key is in the run position, it is taking the voltage from the wrong part of the circuit. At the positive terminal of the coil, the voltage has been stepped down by the ballast so this terminal will only get a fraction of the 12V that the choke needs to open.
That is what I was saying,also it takes a lot of power from the circuit and can pull the voltage down lower ...
