I started doing all of mine from underneath. If I never have to do one over the fenders again it will be too soon. Its really much easier than it sounds. Best thing is you can assemble EVERYTHING on the K frame and then roll it right under and lower the car down. Install t-bars, steering column, upper ball joints, and most of the underneath work is finished.
...FAFO...
