Thanks, guys. And by "sensing," isn't this what they basically do? Sense voltage to tell the alt what to do? Electricity=voodoo ;-)
There is current flowing through the field wires, the "sensing" is done by the regulator via the blue IGN1 wire.
DEPENDING on year setup
on electronic systems that's it. the blue wire section going to reg is the sensing one to make work the regulator and FEED NEGATIVE, sourced by chassis, but not the blue one going to fields... both shares same source but for diff purpouses
on mechanical systems, this blue wire senses ( allong with chassis ground ) AND feeds at the same time to get same kind of positive signal on reg output
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
