not really semantic. The GM speelling is what give us the "SENSING" therm, where actually switches on the regulator and gives the signal to cluster light. Beside the "sensing" wire on GM, they get the SOURCE wire for reg/rotor in a diff wire
the field wires on Mopars actually FEED the alt rotor to be able to produce the output power. No sensing at all
Is not just semantics, is a diff way to work.
The sense wire on the GM was an output to let the idiot light know when to turn on. The field wires on Mopars regulate the output on the big wire by varying the voltage on the field. That was done internally on the GM alternators and because of the heat were a frequent source of failure.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
