I was wondering if the power to the switch on the pedal is supplied from the turn signal switch or does it come from the fuse block to the pedal switch to the turn signal switch?
I have turn signals and running lights but no power to either side on the pedal switch.
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
