As far as changing studs, I have found that the rear studs can be knocked out, or pressed no problem. If the front drums are 11 inch ( several/all I have worked with)the studs could easily be knocked/ pressed in and out using normal back up around the stud location. The 10 inch drums all needed the swedge cut out/ ground out to be able to remove the studs without destroying the hub.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
